oxygen sensor voltage??
Old Jun 28, 2010 | 08:14 AM
RS Classics's Avatar
RS Classics
Default oxygen sensor voltage??
i have just got a turbo timer which reads oxygen sensor voltage. just wondering what it should be for a standard green top sierra cosworth. it reads appx .12 to .14 most of the time.
Old Jun 28, 2010 | 08:22 AM
RS Classics
i have it plugged into the white wire od the lambda sensor is this correct?
Old Jul 6, 2010 | 09:35 PM
RS Classics
Anyone??
Old Jul 7, 2010 | 07:51 PM
stevieturbo's Avatar
stevieturbo
C**t
monitoring narrowband voltage is a waste of time. That's is mostly just for novelty value.
And 0.12-0.14 what ?
If volts, then something isnt right with how you've wired it up.
Old Jul 7, 2010 | 08:56 PM
105epwr's Avatar
105epwr
im sure they scan up and down from 0-5volts,think the white wire is the heater wire,
so 0-5 volts scanning meaning rich-lean.
i think.....
Old Jul 7, 2010 | 09:01 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
i think.....
0-1 v
Old Jul 7, 2010 | 09:10 PM
snoopaloopa's Avatar
snoopaloopa
Yep 0-1v input to ecu then the ecu converts it to 0-5v internally, go figure
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
