How to rewire my fans and feulpump?
Old Jun 27, 2010 | 12:18 PM
BJ Bouwma's Avatar
BJ Bouwma
Default How to rewire my fans and feulpump?
Hallo Cossie drivers,
My cosworth 4x4 fans are not turn in when engine is hot, It has a dubble fan. and on the front a single one with is working.
Last year have changed headgasket for Cometic and also all the sensors also plased the uprated fan switc from MSD.and a new chip (closeloop) the car runs perfect runs verry cool now whith these fan swith.But i think the fans are not working. before the thanse of sensors etc. the fans also come in.
So i think rewire the fans and also feul pump for no problems ad all. hope someone can tell me this maybe white picture??
Spec of my car: closeloop msd,standard turbo and intercooler,greens,mongoose,31 actuator,3bar map sensor,grp a dumpvalve
Old Jun 27, 2010 | 12:28 PM
LHD220Turbo's Avatar
LHD220Turbo
fuel pump.
you can take the earth back to the battery if you prefer (which is what i did) and you can use a single throw relay relay rather than double (both will work)
Old Jun 27, 2010 | 12:31 PM
LHD220Turbo
see here for the fans which may help you
https://passionford.com/forum/ford-s...g-diagram.html
Old Jun 27, 2010 | 01:17 PM
As said all on here, just do a search.
Old Jun 27, 2010 | 01:41 PM
Thanasis's Avatar
Thanasis
the original loom has problem with a lot time work - warmed,so go for new fans loom straight from battery with relay 70A!best choice mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
