dvd handycam and twin switchable bullet cam set up ............£200
bought this dvd handycam a while back and a load of bullet cam stuff and mounts etc when i was tracking my xr2 turbo,
my new cars not going to be ready for a long while yet so only selling this to free up the cash while its not being used,
The mini dvd handycam model number DCR-DVD405E google it for full spec etc but main thing for me was that it has AV IN so could be used with external bullet cams,
is in perfect working order, all touch screen etc so great for the holidays or any other event or occasion you want to put on dvd, complete with charger, pc lead, remote and all instructions and box,
expensive sony handy cam padded carry case with a few pockets and internal divider to keep everything protected
this little set up alone was expensive and is still top quality now.
TRACKDAY BULLET CAMS AND EQUIPTMENT
here is all the trackday stuff i have for sale everything works perfect as it should be,
2 x 8 aa battery holders
2 x bullet cams - one higher quality than the other but both very good
1 x tri suction camera mount with safety strap
1 x ring clamp bullet cam clamp mount with threaded boss
1 x 5m av lead extension
1 x remote on/off record button to dash mount - for above camcorder only
1 x bullet cam switcher to run 2 bullet cams and record either camera at the flick of a switch front or rear, inside or outside cam etc
1 x ciggarete lighter power lead to suit bullet cam
1 x basic microphone
1 x cullmann/fast films.co.uk roll cage camera mount cost
very extensive kit for track days etc and with a very good mini dvd recorder which is also great on its on for when your not on track or to film from the pit wall etc
£200 for a quick sale
Passionate about fords
Do the bullet cams come with everything needed and inc their original cases and manuals so setup is easy just like new ones ????. Do you know which models the bullet cams are ????.
Can the camcorder record to memory stick ????.
How good is the microphone and where did you have it mounted ?????.
Dave.
Dave.
Everything you need us there and it all works,
no idea if it would record to memory stick only ever used DVD,
can't remember the makes of cams but 1 is pukka quality and 1 is good quality,
no instructions but I will either write or show the buyer how it plums in but most of it is self expanitry,
look on YouTube under KINZY1 for some of my vids using the set up but the sound on YouTube gets messed up for some reason and the mike is very basic but does the job,
I borrowed a mates one with variable gain etc and it was alot better
thanks Marc
thanks Marc
Adam Graham
Sep 6, 2015 06:04 AM
rog
Sep 4, 2015 07:24 AM
