how do i test my radiator fan
Old Jun 21, 2010 | 08:19 PM
mondeo manx's Avatar
mondeo manx
Default how do i test my radiator fan
Hi
I'm Just Wondering how to test my radiator fan on my ford mondeo mk2
thanx Dave
Old Jun 21, 2010 | 08:21 PM
fiestamad's Avatar
fiestamad
start ur engine up and let it run and if it does not turn on at the certain temputer then it will be broke mate
Old Jun 21, 2010 | 08:33 PM
turbobill's Avatar
turbobill
you can also wire it to a battery to make sure the fan actually works
Old Jun 21, 2010 | 08:35 PM
RichieST's Avatar
RichieST
Take off the wiring plug on the fan switch and bridge the terminals together with a paperclip or something. Turn ignition on and it should come on.
Old Jun 22, 2010 | 07:41 AM
Don't need to do any of the above, just unplug the wire from the CTS sensor, the ECU one, fan will come on and run all the time this is disconnected, also shows you cts signal is being received then as well.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
