Clutch Questions 4x4
Old Jun 21, 2010 | 08:08 PM
T4T's Avatar
T4T
Default Clutch Questions 4x4
Hi all rebuilding my car and have a have a couple of questions re clutch . Are the hydraulic kits (reyland) for example a one size fits all or do you get different master/slave combinations for different pressure plates ? The reason I ask is I have what I believe to be a fairly heavy duty one . Used to use it with cable ( which didn't break ) but it was rather heavy !!!!! The next thing is what torque rating does my cover plate / disc combo have as engine upgrades have changed things somewhat .
Friction disc is cp2496-16
Coverplate is cp3380-6
Thanks Matt
Old Jun 22, 2010 | 07:45 AM
One size fits all for ther hydraulic clutch conversion, it will be MUCH MUCH lighter with it being hydraulic, a lot of effort is wasted in the cable systems overcoming cable friction let alone diaphragm tension, you won't be dissapointed that's for sure with hydraulic.
I'm using land rover series 2/2A slave and master cyl(Ł26.58 the pair delivered NEW) on mine.
Old Jun 23, 2010 | 08:35 PM
T4T's Avatar
T4T
That's good to know .
Any ideas on the torque rating anyone ?
Matt
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
truffleshuffle
Sep 10, 2015 09:35 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
Escortdriver1
Sep 6, 2015 10:12 AM
