Small turbo Escos engine
108k and needs a freshen up (bit rattly). Removed it from my car a couple of months back, was running fine. Would prefer to sell complete but may break if there is enough interest.
Comes complete, with the exception of: inlet manifold, phase sensor, water pump, thermostat housing, cambelt and engine mounting arms. Still has sump, front diff and front prop attatched. P.m if you would like my number or pictures.
Offers around 2k. Dont be shy!
Thanks, Matt.
Thanks, Matt.
seems a bit steep realy mate as ive just paid for my engine thats being built now 1200 it cost me without the manifolds and that but that is for a fresh engine,i think all together with the parts ive had to get to complete the engine it only cost me 1800 and thats with a recon t3 turbo/manifolds etc
I said offers around 2k so I am obviously looking for offers near that.
Was it a 2wd engine you bought?
This is a small turbo engine i.e the best one to start with! It isn't fucked by any means, just needs a freshen up like I said.
At the fucking retards on this thread....Small turbo block- best casting available for big power, no rear core plug, spray jets in the block, worth Ł800 all day long
Small turbo head, more meat for porting, worth Ł600 all day long
Crank std/std worth Ł400+ all day long
Plus all the other bits and bobs, 2k or sensible offers is a bargin...
the only problem is will, std/std crank for Ł400, yeah i agree, but thats what the likes of a trader will get or an engine builder charge if they supply one, but i had 2, and i advertised them for Ł250 each for easy sale and no one even batted an eyelid, ended up selling them for considerably less.
imo, the engine is worth Ł1600 given mileage
would you be willing to take this engine to harvey at scs , for him to check it over. i will be needing a donner engine for a 2.2 stroker build , so the crank ect is of no use to me. as long as the block and head is ok thats all i am looking for.. was the engine running ok , did it blow the gasket or anything..
pm me your phone number and we can talk, if the engines ok and you will deliver it to scs i will have the cash there wateing on you.. i will pm you an offer later
many thanks steven..
I do need to sell this engine, hence why I have it up for sale; however; if you are not going to make an offer anywhere near to what I said I would like for it, please don't bother. Also, if you consider it to be worth the same as a 2wd engine, then there are couple of those for sale on here ATM; hit the back button on your browser and make an offer on one of those.
