Red glowing manifold.
Old Jun 21, 2010 | 04:25 PM
Butchi's Avatar
Butchi
Default Red glowing manifold.
Hello guys! Im concern about one thing.
What can make a manifold glow? Its getting very hot and I only have the turbo at 0.8 bars.
Its getting hot even when I drive normal.
Br Butchi
Old Jun 21, 2010 | 04:33 PM
gus's Avatar
gus
timing too advanced?
Old Jun 21, 2010 | 04:46 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Too retarded more like.
Old Jun 21, 2010 | 04:48 PM
retro d's Avatar
retro d
Retarded to much, sort it out before it melts lol.
Old Jun 21, 2010 | 04:51 PM
gus's Avatar
gus
guess im the retarded one then
my bad
Old Jun 21, 2010 | 04:58 PM
retro d's Avatar
retro d
my bad
lol
Old Jun 21, 2010 | 08:51 PM
Butchi's Avatar
Butchi
So, whats normal for the rs turbo? 12 degree at idle and somewhere 25-28 degree at full power?
Br butchi
Old Jun 21, 2010 | 08:58 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
TOo retarded
too lean
but if its just after you thrash it its fine
Old Jun 21, 2010 | 09:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
IMO Advance at WOT full load will be anywhere between 10deg BTDC and 20deg BTDC depending on your full spec, ACT's, fuel RON, Boost, EGT's, etc..
25-28deg is too advanced in which case your probably detonating
Old Jun 23, 2010 | 06:15 AM
Butchi's Avatar
Butchi
Ill will ckeck the timing again. But the thing is, the car runs very good. no missfire or anything. The sparkplugs shoes a light brown/grey couler.
How about the heat wrap around the manifold and elbow/exhaust? Its new. Have never had it before. Can this be the problem that heat cant come out from the manifold and exhaust? Think Ive heard someone writing of this problem before?
Br Butchi
Old Jun 23, 2010 | 12:19 PM
smudger068's Avatar
smudger068
when i used to have my 4-1 manifold heat wrapped it used to glow through that after a good thrash ony upto 4 1/2 5000 rpm, without heat wrap it neva did sooo...
Old Jun 23, 2010 | 11:38 PM
Butchi's Avatar
Butchi
PROBLEM SOLVED!!!!
It was the heat wrap around the manifold. I removed it an after it was fine.
Thanks for all help and advise guys.
Br Butchi
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
