Brake compenstor valve
Jun 21, 2010 | 06:40 AM
On my 3 door is leaking again , does anyone know where you can get these new as fords no longer sell them . Just above the rear arm passenger side !
Jun 21, 2010 | 05:04 PM
Jun 21, 2010 | 06:05 PM
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Not sure mate. Mine was leaking years ago. If i remember rite, I just removed it and stripped it apart and replaced an O Ring. Maybe not though lol sorry
Jun 21, 2010 | 06:21 PM
It doesn't need to be cossie specific, so any sierra with rear disc will do, or from granada, scorpio etc, so long as rear disc is ok.
Jun 21, 2010 | 06:51 PM
Cheers mate . need one asap as is pissing out all over the place. anyone in essex breaking any of the above cars ???
Jun 21, 2010 | 09:06 PM
i couldnt find one for love or money, so i just removed it
Jun 21, 2010 | 09:28 PM
One on ebay the other day
Steve
Jun 21, 2010 | 09:41 PM
I remember someone on here once wrote that Fiesta ones (I don't know which model) are the same as Sierra ones.
Jun 22, 2010 | 06:38 AM
Quote:
Originally Posted by
LHD220Turbo
I didnt think you could do that ?
Jun 22, 2010 | 06:56 AM
Harris.
You can do it, just not safe to do so.
The valve does not even have to be ford either so long as fits, from a rear disc RWD car.
Jun 22, 2010 | 06:57 AM
Ive had no luck finding one so far
Jun 22, 2010 | 07:41 AM
Does anyone have ford microcat ? part number 6132856
Jun 22, 2010 | 07:31 PM
mines leaking too
Jun 22, 2010 | 07:47 PM
garry c
mines leaking too
Wouldnt be to bad if good old fords still sold them would it , i went in there today and spent 20 mins trying to drum it into the tit that cosworths didnt start from 1990
Jun 22, 2010 | 07:49 PM
Check here.
http://rs500.yolasite.com/
Paul S is selling some 3dr/500 bits - thats the link to his site i think.
Just over half way down -
'brake line front to rear inc good leak free bias valve 65'
Mart.
Jun 22, 2010 | 07:51 PM
Moonstone Mart
Check here.
Mart.
Ive been contacted by him mate and only need the valve not the line and he wants to sell complete
Jun 22, 2010 | 07:53 PM
Righto - was worth a shot
Mart.
Jun 22, 2010 | 07:57 PM
Well just buy the valve and tell him to bin the line........simplessssss
Steve
Jun 22, 2010 | 09:13 PM
Moonstone Steve
Steve
I may well be doing that
Jun 22, 2010 | 09:25 PM
I've still got the old valve off my Sapphire Cosworth which I painted black. pm if interested with an offer!
Jun 23, 2010 | 07:46 PM
Ok so tonight i have paid for the one of Paul s (thanks mate)
Next question is . HOW do you fit the thing
Jun 23, 2010 | 08:09 PM
ive got my old leaking one in my shed i think, if i recall correctly it splits in 2.
if nobody can confirm i'll go dig it out and have a look
Jun 23, 2010 | 10:40 PM
Brake valve
I have one if you want it - it is slightly modified, it is from a 4x4, the internals are the same but the fitting heading to the 3 way connector is different, I have had a goodridge adaptor fitted and the a new short pipe valve to 3 way, the female threaded hole facing towards the front of car is the same, works the same as original no leaks etc, if you are interested let me know as I have just started to brake my car
Regards Ry
Jun 24, 2010 | 07:03 AM
Its very staightforward to fit - spanner on the body of the valve to hold it in place, and a 11mm spanner on the front brake pipe end and just undo the brake pipe union, then the same at the other end of the body with a slightly larger spanner ( think it was 13mm), remove the body and replace and tighten the unions back up either and and job done, just need to bleed the system then.
Jun 24, 2010 | 04:53 PM
Thanks for the advice paul .
Jun 24, 2010 | 05:20 PM
on its way
Jun 24, 2010 | 06:32 PM
PAUL S
on its way
Thankyou
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
