380cc Injectors for std engine??
Old Jun 20, 2010 | 08:33 PM
Red_bull's Avatar
Red_bull
Default 380cc Injectors for std engine??
Hello guys,
I'm building a engine on megasquirt. I'm offerd now a set of 380cc injectors, but are they good for a standard engine? I'm only going to turn up boost appart from that it will be a std engine.
Are these injectors good or too big?
Old Jun 20, 2010 | 09:59 PM
Rick's Avatar
Rick
They'll be fine mate. Rover turbo are 380cc.
Old Jun 20, 2010 | 10:01 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
as above mate they will be fine
tommy
Old Jun 21, 2010 | 12:21 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
they'll be alright for a big of extra power, i had some rover turbo ones turned up to flow 440cc, but they weren't great over 10psi of boost on high revs though, zvh uses quite a bit of fuel to get the power out though.
Old Jun 21, 2010 | 06:58 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Be ok for up to about 190-200bhp mate.
Old Jun 22, 2010 | 08:09 PM
Red_bull's Avatar
Red_bull
how much cc are you guys running and what's your set up?
Old Jun 22, 2010 | 09:26 PM
Karlos G's Avatar
Karlos G
Balls Deep!
630cc on a 1.6cvh, T3 (.36/50), 20psi boost, injectors are at 68% Duty full load WOT 231bhp.
My old 480cc injectors where at 106% Duty at that boost.
Old Jun 22, 2010 | 10:25 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
630cc siemens deka, same as Karl, 1.8zvh 4wd cossie turbo .048 housing, 23psi of boost, max of 80% duty so far.
they will run less duty for same boost on my zetec turbo engine i'm planning to build in the near future though.
Old Jun 23, 2010 | 07:48 AM
crazycage's Avatar
crazycage
630cc will do a solid 450hp on a zetec
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Toe Knee
Aug 23, 2015 08:31 AM
Zoggon
Aug 10, 2015 10:39 AM
