Fuel metering unit again...
Looking at the fuel metering unit, on the fuel return pipe there is a small cylinder of some sort which i believe has two other fuel pipes coming off of it... on this cylinder there is also what appears to be a fitting for a vaccum pipe.... is this the case and if so where does this pipe come from?
155lee
Oct 24, 2015 11:11 AM
