avo coilovers on 4x4 saph cossie?
Old Jun 19, 2010 | 11:31 AM
col93saphcos's Avatar
col93saphcos
Default avo coilovers on 4x4 saph cossie?
thinking of avo coilovers,300lb front and 200lb rear seems to be the poundages of springs,
are they ok poundage wise?
been asked loads but is it worth doing?
on koni and bayjoo(supposidly)springs just now,seems ok on good roads but on crap roads like im normally on car seems to feel is if front has alot of bump steer,
any advice muchly appreciated
cheers colin
Old Jun 19, 2010 | 11:52 AM
Not 4wd(tractor ha ha!!) but have this on me 2wd sapphy, 300lb 9" front 200lb 12" rear, but imo rear is a tad too soft, will be trying some 225 or 250lb rear, when engine rebuild done.
It's defo firm, but VERY controlled and I like it, no one really finds it uncomfortable, esp in rear.
Old Jun 19, 2010 | 12:16 PM
col93saphcos
just i was kind of under the impression with 4x4 its better softer at front than rear??
i'll go put konis to hardest at front and see what like today
just getting bit fed up wasting money trying to get handling right,
cheers colin
Old Jun 19, 2010 | 01:17 PM
stucos71's Avatar
stucos71
Is it for road use??
Been told coilovers are too harsh for the road, if the car is used regular.
Know 3 guys who fitted them to road cars, then took them back off.
Depends if you dont mind compromising the driveability of the car.
Made that mistake by fitting an AP paddle clutch, ruined what was an enjoyable car to drive.
A decent Koni kit on hard setting is plenty for the road IMO.
Old Jun 19, 2010 | 01:45 PM
col93saphcos
yes only used on road,
cheers
Old Jun 19, 2010 | 04:07 PM
stucos71's Avatar
stucos71
cheers
I'd just turn up the Konis mate. Each to his own!!
Others may disagree tho.
What i've been told is good enough not to change mine.
Old Jun 19, 2010 | 04:13 PM
col93saphcos
used everyday on the road,will just be heading out,
so i will try hard setting on front,rears are hardest setting,think im 1/2 turn from hardest setting on the front,
cheers
yatta
May 21, 2016 10:31 PM
yorkie92
Sep 6, 2015 05:34 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
