2wd and 4wd Saph Konis the same ?
Old Jun 19, 2010 | 11:02 AM
gazcos's Avatar
gazcos
Default 2wd and 4wd Saph Konis the same ?
Can anybody confirm whether 2wd and 4wd koni kits are the same or not ?
Cheers Gaz
Old Jun 19, 2010 | 11:03 AM
Saaamon's Avatar
Saaamon
The hubs are different i think mate.
Old Jun 19, 2010 | 11:10 AM
The Youth.'s Avatar
The Youth.
on the rear there the same on the front the 2wd has a smaller hole in the hub to fit the shock in, you can fit a 2wd strut into a 4wd hub using a sleeve but you can't fit a 4wd strut in a 2wd hub
steve
Old Jun 19, 2010 | 11:27 AM
gazcos's Avatar
gazcos
steve
Ok mate, are these sleeves available anywhere or is it something i'd have to knock up myself ?
Cheers Gaz
Old Jun 19, 2010 | 11:59 AM
The eye at the bottom of the rear shocks has a longer "tube" through which the bolt passes on 4wd, so they may do 2 different ones or just use the shorter 2wd version and supply 1/4" spacers to go either side of the eye fitting, would mean only needing to make one strut then, but easy to enough to sort out.
The fronts are as said.
Old Jun 19, 2010 | 12:48 PM
The Youth.'s Avatar
The Youth.
to sleeve them just get some thin steel and wrap it round the strut before putting it in, my m8 did this a few years ago on his track car and it hasn't fell out yet!
steve
Old Jun 19, 2010 | 01:01 PM
gazcos's Avatar
gazcos
Thanks for the replies chaps ,very usefull
Nov 1, 2015 06:53 PM
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
