what coolant for my cossie
sorry if i sound thick but noticed a leak and when i had a look my jubilee clip had loosend off so i tightened it and filled up with a little bit water but i know it has to be 50/50 but didnt have any at the time and there was still some in the bottle so i think ill be ok but want to get some so i can keep it 50 50 cheers
well i went to my motor factors today and they give me 2litres of coolant said drain the lot and start again so i did ant put the full 2 litres in, then about 2-3 litres of water is that right its what he saidf to do and my leak still hasnt stopped fitted 2 new jubilee clips and moved car so icould check if there was any fresh marks on the floor and there is
All I ever do is drop the lot, then add the antifreeze first, so you know there is enough in there, it doesn't need to be exactly 50/50.
I use the orange(USAFE) when I can "borrow" some, 10 year life, and I still change it every 2 years!!
they react and congeals (sp?!) as theres different chemicals in them!!!! Not good lol.
U said not to use pink, but how do u know its not got pink in already
As said best bet is to drop the lot and change it all!!! The only difference other than the chemicals is the life of it really but its best to change it every few years anyhoo!!
Russ Payne
Sep 25, 2015 08:29 PM
