cossie brakes
Can someone explane how the fook there supposed to feel, when i turn the ignition on i can here it buzzing and then stops after a few seconds, now the pedal has always had the same travel since i have owned it but occasionaly at slow speeds when i brake gently i can here the buzzing sound, the pedal goes quite firm and the brakes feel so much sharper.
Do i have a fault somewhere, i have put a meter on the abs sensors and they all read wot the book states.
Cheers.
Steve
Cheers.
Steve
As said the system is working normally, pump should run for a while when turned to position 1 and then stop, ABS light should also estinguish after a self diag in position 2, however this is a common problem which I have myself, never really bothered with it as it's never caused me bother.
It's when you are going about 5MPH then go to brake isn't it, the pedal goes hard and you get a noise?
My thought is it's caused by air being in the system, rather than a sensor fault as when it happens the ABS light never illuminates.
Martin
Martin
The Enigma
Sep 12, 2015 10:12 PM
