Cut the door off/open!?
Old Jun 17, 2010 | 10:16 AM
the mk1 kid's Avatar
the mk1 kid
Default Cut the door off/open!?
Hi all,
Seems daft to even think it, but it popped into my mind when i spent an hour tyring to open the rear door of the focus, and then the local garage got no where!
Its the other halfs car, and i know she needs really to pop to a ford garage incase there is a sneaky trick to remove/break/force the lock from inside/out, but with the door closed you can't obviously get to the bolts that hold it in position - arse!
Yes the cable and handle work and are connected (the door card if off..) - its definately something with the lock itself thats fubard.
Any ideas guys, as much fun as it would be cutting it open with a 230mm grinder in the street i'd prefer not to have to!?
Tom
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Vincereese
Sep 17, 2015 10:34 AM
Mark V8
Sep 13, 2015 09:34 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
