Sapphire Front bumper removal
Hello all,
I'm having a right nightmare getting the front bumper off..... the bolt on the inner wing are just spinning and I cant get anything on the back of it to stop it....
Any ideas anyone, surely I can't be the only one that's had this problem??
Not sure I can even fit a grinder in there to take the head off it
HELP!!!
HELP!!!
if you can get the black moulding off there should be a few pop rivit's. try drilling them out as they hold on the bracket. once the bumper's off you should be able to get to the spining bolt.
I used a die grinder to grind away the bolt head, then after getting the captive "nut" bit out drilled through, sawed a little of the bracket away so now I can get a SS bolt all the way through both bits and put a SS nut on the other side with a large washer under the nut, fiddly yes but hidden and works 100%.
5 rivets and off she came!!
I then grinded the head of the nut off keeping it cool with water and pulled the bolt through,
thanks
jessie_rs
11
Jun 3, 2019 04:57 PM
