Sierra cvh to pinto
Old Jun 12, 2010 | 05:07 PM
DaniAv's Avatar
DaniAv
Default Sierra cvh to pinto
Hi ,
I owned an sierra 1.8 clx with a cvh engine.
After one year i decided to do a little project and replace the cvh with a 2.0 litre injection pinto engine.
The injection system will be removed for twin weber 40 carbs.
The question is:
Which parts i have replace to match the pinto 2.0ohc twin carbs Instead of the cvh 1.8 engine?
thanks
Old Jun 12, 2010 | 11:09 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
your gearbox should bolt up ok. Yot'll just need photo mounts and maybe a small adjustment to your wiring loom. Or a complete loom
Old Jun 13, 2010 | 08:40 AM
MERKUR XR4ti's Avatar
MERKUR XR4ti
MERKUR XR4ti
I dont think for one second a CVH bellhousing is the same as a SOHC bellhousing. The hole of the exhaust system is wrong too. you will need SOHC T9 bellhousing, motor mounts, I think rad and exhaust, the starter should be the same if the CVH has it on the bottom left, my LHD had it on the right so that was wrong too. and as you say not alot of wiring though if you got carb's . the efi will love the carb's too .
Old Jun 13, 2010 | 10:39 AM
martysmartie's Avatar
martysmartie
What he ^^ said, CVH exhuast is on left hand side, Pintos being on the right hand side.
The CVH Sierra has management (ESC Hybrid), and will be have a Pierburg 2V carb or will have CFI if 1990 onwards, the management will be different to that of the EFI Pinto, but as you are going with carbs then you won't be requiring this anyway. You will just need to sort the ignition side out as this will be electronic.
Martin
Old Jun 13, 2010 | 09:15 PM
DaniAv's Avatar
DaniAv
gear box and exhuast for the pinto - i got.
i have to replace the motor mounts?
Old Jun 14, 2010 | 04:10 PM
MERKUR XR4ti
MERKUR XR4ti
You may have to swap them for the SOHC one's, but Im not sure on that, as I haven't done this my self. I will ask My matey who have give me a min or so and I will be back.
Old Jun 14, 2010 | 04:44 PM
MERKUR XR4ti
MERKUR XR4ti
yes you will need the SOHC mounts but only the Ali part that comes off the side of the block and fits on to the bolt and rubber part. They are all ok to use 1.6 1.8 2.0 and cosworth 16v. so he said
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
