mk1 wheel bearing
hi guys just need some help before i waste more money.
right basically the rear wheel bearing was nackad. when i checked the wheels there was no movement just vibration. so found which 1 was bust got it pressed out, new 1 banged in. 3 weeks later start hearing noises from the rear wheel. jacked it up rocked it about and its wobbling. so bought new bearing removed the hub the bearing had bust in half after 3 weeks. fitted new 1,got everything back together gave it a quick check, still wobbling. so its either the hub or the stub axle just need to no which 1.
cheers
cheers
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
