Ford focus management
Old Jun 11, 2010 | 08:40 AM
CHRIS@SMYTH's Avatar
CHRIS@SMYTH
Default Ford focus management
Hi, my name is chris.
We have done 3- 4 engine management diagnostic tests on an 1800 petrol ford focus, 2002. The same code keeps re-occuring which is po141. We have renewed both lambda sensors but management light comes back on after only a mile or so. Has anyone any ideas? Always states that heated circuit is faulty,any tests for this?
Last edited by CHRIS@SMYTH; Jun 11, 2010 at 08:41 AM. Reason: FORGOT TO PUT YEAR OF CAR.
Old Jun 11, 2010 | 08:49 AM
RichieST's Avatar
RichieST
If the sensors are dropped it can knacker them as they are very fragile. Could it be that the new sensor has been damaged? Could be worth changing the pre cat sensor again. I think they also use the coolant temp sensor to measure the temperature switching time. Could be worth changing this sensor too just to rule it out?
Old Jun 11, 2010 | 12:36 PM
CHRIS@SMYTH
Thanks very much for advise.
Chris
Old Jun 11, 2010 | 06:02 PM
oldford's Avatar
oldford
P0141 - O2 Sensor Heater Circuit Bank 1 Sensor 2
Bank 1 sensor 2 is the post cat sensor. You only need to look at the post cat sensor. Pre-cat O2 sensor has got nothing to do with this problem.
Seems the heating is not working (correctly). Check wiring and fuses.
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
