wireing help
Old Jun 10, 2010 | 03:16 AM
robgee32's Avatar
robgee32
Default wireing help
how easy is it to fit a fiesta rs turbo ofac loom to my existing escort mk6 efi loom
what do i need to do as my ecu is in the car and the fiesta one sits on the outside
hope someone can help
Old Jun 10, 2010 | 05:31 AM
rubinsbin's Avatar
rubinsbin
Wireing!!!!!!!!!!!!!!!!!!!-lol >>>>>>>>>>>>>>>>>>>>>>>>>>>>>wiring
Old Jun 12, 2010 | 08:12 AM
JonathanJ's Avatar
JonathanJ
Well as i am in the middle of doing this for a friend , will give you my thoughts , he has a escort cab , he has broken his fiesta turbo which gave him an ofab loom and ecu , last weekend we decided to see if it was possible to use the separate loom with his car .
I have come to the conclusion that it will be easier to use a ofac ecu with the original efi loom and if he wanted to have the amal valve fitted just add these wires into the original loom , this will make the installation seamless in as much as the ecu in within the car and the wiring is as standard.
Hope this helps
Old Jun 13, 2010 | 08:18 AM
robgee32's Avatar
robgee32
cheers jj
so you are saying that you can add the ofac loom to the mk6 efi loom without any problem
so i install the stuff into the engine bay what do i do with the ecu in the car do i unplug it or do i leave it in to run any other componants ie lights etc
i am new to wiring but i like to trial and error
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
