SOLD COSWORTH 4X4 ENGINE, T38 TURBO, MSP COIL PACK, AIR INJ, MSD MAPPED 450+bhp SOLD
sierra cosworth 4x4 engine late style like esc cos, 1993 200 block 450+bhp £4000
kent vernier pulleys
bd14 inlet cam
standard exhaust cam
ported and polished head
new valves and guides
multi layer head gasket steel
mahle low comp pistons and rings apr conrod bolts
new big ends and little ends thurst washers
balanced crank flywheel
alcol 6 paddle clutch
5 bar high lift oil pump
new water pump
t38 roller bearing with turbo damper and 2wd exhaust manifold. baily turbo oil filter
swedish plenum inlet & throttle bracket
grey injectors
new timing belt kit
coil pack conversion and leads new m.s.d
arp stud and nut kit
air injectors new m.s.d
4x4 engine loom
level 8 ecu lived mapped motor sport development
£2000 spent at motor sport development just last year
engine built was last year, basicaly complete, ran in and ready to go
prices SOLD SOLD
bd14 inlet cam
new water pump
grey injectors
new timing belt kit
4x4 engine loom
prices SOLD SOLD
If you split you may make more money that way.
If you do , i will have first dibs on coilpack and turbo oil line with the bailey oil filter . Plus crank position sensor.
