Mahle Pistons Forged or Cast
Can someone give me some advice on these pistons i have , they are Mahle , stamped on the face is sp 0027 , 80,443 (oversized .50mm) with 86 T and an arrow. Question being are these forged or cast?
Any help much appreciated.
Ken
Ken
Yea , there is Mahle with A1 under it , 80v157+ to the left of the word Mahle , theres also a p 031, a 16 with a 7 under it enclosed in a circle and the number 80st138 stamped inside.....oh and on the face there is a stamp with made in Germany and 515 stamped....
CheeRS Daz , i think going of the pics my ones are most likely cast
, but if anyone has a nice picture of a mahle forged one then please show us . By the way Daz them pistons and rods are the muts nuts
The rods and pistons cost a fooking mint too! Not much change out of 1.5k but that also buys a little bit of peace of mind...
Tell me about it Scott , in the Burtons catalog the pistons are called Mahle/Forged then on there online catalog they come under the Cast pistons section, same part number
... my ones look like both.... god damn confusing....
No you're not if they are of the same type than std. RST pistons. I run 20psi daily and have experimented with upto 30psi with no problems what so ever. I'm running the std. RST pistons and thus standard compression too.
Of course the fuelling and ignition has to be bang on.
Originally Posted by sjoyce666
whats the deal with these then as they're shiny, mahle but yet come under the cast section of burton powers catalogue
Scott
i brought some Ross Racing pistons the other day for mine 1mm oversize , forged low comp ones from P.T.S nearly 500 quid though, susposed to be good, they put them in drag cars etc.
But untill i get the car back on the road, i dont know how good they are!
[quote="grimmeRST"]i brought some Ross Racing pistons the other day for mine 1mm oversize , forged low comp ones from P.T.S nearly 500 quid though
Bloody pts told me they want £570 for a set
and a 5 week waiting list
Just ordered some cosworth racing pistons from burton
Yeah i was lucky they had one set on the shelf, if not they come from the USA!.
Got the Cosworth ones then!, they are meant to be good according to alan!.
Mine should be back on the road in 2 weeks!!!, thank god.
As above there is no true forged Mahle piston.. all there pistons are 'squish' cast for want of a better word (and not knowing the propper term
) the metal is put under pressure into the casting thingio and out comes a harder than normal cast piston due to the metal being forced in so you dont get air bubbles etc in them.
Mahle pistons are good for 30+ psi of boost but they cannot disipate heat as well as a true forged piston and are obviously not as strong.
) the metal is put under pressure into the casting thingio and out comes a harder than normal cast piston due to the metal being forced in so you dont get air bubbles etc in them.Mahle pistons are good for 30+ psi of boost but they cannot disipate heat as well as a true forged piston and are obviously not as strong.
deathrider666
Sep 28, 2015 06:12 PM
CrOwSoN15
Sep 10, 2015 07:33 PM
