cenral locking
Old Jun 6, 2010 | 06:51 AM
rammer's Avatar
rammer
Default cenral locking
can some one shed a ray of light on this question please,
the previous owner of my mondeo never renewed the battery in the door key, not sure how long this had elapsed but the doors will only lock manually. I have been told that if I renew the battery the car will still not lock, as the the car has to be reprogramed by a ford dealer. Is this the case or can I get around it somehow, I have a spare red igniotion key that came with it, any advise please
Old Jun 6, 2010 | 07:04 AM
FORD RS MAD's Avatar
FORD RS MAD
Ford model mad
Hi,i had the same problem although with my subaru impreza.my battery went in the key fob and it wouldn't lock the doors and it prevented me starting the car.I took the old battery out then replaced it but unknown to me as i left the battery out too long the key needed to be re-programmed to match my immobilizer.Hope this helps and good luck.
Old Jun 6, 2010 | 02:23 PM
rammer's Avatar
rammer
Hi Many thanks for that,not sure what the next step is from here but will have to consider taking it to a ford dealers
regards
Rammer
Old Jun 6, 2010 | 05:51 PM
gtinutter's Avatar
gtinutter
i know the 51 plate mondeo withthe three buttons on the key u can code from the car yourself all u do is turn the key on and off three times until u hear a bip then press unlock or lock m8 thats it done loads but odd one u need the all seatbelts pulged in hope this helps
Old Jun 6, 2010 | 07:33 PM
Depends a lot on age of the mondy, with mk1 and 2 you should be ok just replacing the battery and all will work again.
Old Jun 7, 2010 | 07:10 AM
rammer's Avatar
rammer
Many thanks
for the reply, do you know the signifignance of the red key, I.E. the 2nd ign. door key please
rammer
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
