Speedo Cable Assistance Required
Morning all,
I have to change my speedo cable this morning but I'm not sure of the best way of going about it. If any of you could offer me some advice it would be much appreciated. Many thanks in advance, Simon
Very easy to do, can even do it without removing clocks totally, I would take out screws etc holding the clocks, then squeeze the conencdtor on the rear where it(clip) is serated this will allow you to pull from the clocks, now under bonnet pull through bulkhead, remember the route then disconnect at box end, with circlip pliers etc, refit in reverse order, nothing difficult to catch you out on this job, just make sure the cable inner is in at least 1/4" or so into the drive bit, some can be a tad short, and jump out the drive pinion.
i would do one thing to make sure no little twits put it in place drive a mile not connected to the speed make sure loser ! and connect to the speedo locked in place and in the engine bay pull back about a inch to take the little slack as i done the change before to fine was not 100% a broke within 100 miles
wowk
Mar 30, 2021 07:49 PM
muz
Sep 30, 2015 08:29 AM
