ECU fried
Old Jun 1, 2010 | 02:00 PM
kermitt's Avatar
kermitt
Default ECU fried
How do you know if your fuel ECU is fooked? Was speaking to a guy at work today and told him what had happened the day before and about the spark plugs being black and he mentioned the same thing happened to him albeit in the Punto he was using. So he swapped the ECU for another and now works fine.
Old Jun 1, 2010 | 05:24 PM
kermitt's Avatar
kermitt
mfi bud. It was last setup when running 15psi but since the rbuild i wound the bleed valve back as far as it would go. Have done 100 miles since and it seemed ok till now when i was out giving it some but started to slow down when i put my foot on the accel pedal. After it stopped i can't get it to start and the plugs are black but fine b4 i took it out for a spin.
Old Jun 1, 2010 | 06:04 PM
kermitt's Avatar
kermitt
plugs are dry just checked. I wound the bleed valve in to reduce the boost for the rebuilt engine but fuelling etc has not been setup since before the rebuild. It did seem to run well as i managed 100 miles on the fresh engine without a setup but now not starting. Am gonna nip out and make sure its getting fuel just to be sure.
Old Jun 1, 2010 | 06:58 PM
RSargie's Avatar
RSargie
check the fuse hasnt gone for the fuel ecu as well this somtimes goes and or bad conection in the fuse box. the fuel ecu has a cold start enrichment function so if it isnt working it wont start when cold
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
