Cosworth T45 driveshaft bolts
Old Jun 1, 2010 | 05:07 AM
Cossy Mike's Avatar
Cossy Mike
Default Cosworth T45 driveshaft bolts
are they the same on 2WD as 4WD??
Mines 4WD and missing one, I am in need of one and have heard they are ultra hard to find with being imperial thread?
Old Jun 1, 2010 | 06:06 AM
BLACKCOS's Avatar
BLACKCOS
they are diffrent it should be t40 heads on the 4x4.
Old Jun 1, 2010 | 01:08 PM
Cossy Mike's Avatar
Cossy Mike
Are they readily available still? or are these the ones you can't get no more?
Old Jun 1, 2010 | 06:01 PM
cossytel's Avatar
cossytel
They are metric m8 4x4 m10 x 1.25 2wd
Old Jun 1, 2010 | 06:03 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Just get some high tensile 12.9 allen caps instead - Much easier when it comes to removing them then
Old Jun 1, 2010 | 06:36 PM
Cossy Mike's Avatar
Cossy Mike
Brilliant thanks!
Is it safe to replace them with Stainless steel bolts??
Old Jun 1, 2010 | 06:43 PM
cossytel's Avatar
cossytel
Brilliant thanks!
As above 12.9 socket head cap screws
If you want shiny then bzp are readily available but expect to pay around a quid each
Old Jun 1, 2010 | 07:01 PM
Cossy Mike's Avatar
Cossy Mike
bzp? do you mean Bright Zinc Plated?
I am willing to pay but I have heard not to replace certain bolts with Stainless as they are too brittle.....
Old Jun 1, 2010 | 07:52 PM
cossytel's Avatar
cossytel
To clarify, I wouldnt recommend stainless i am no expert but i would imagine they would probably fail. The 12.9 is a High tensile steel fastener to BS and yes Bright zinc plated.
Old Jun 1, 2010 | 09:26 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
if you cover the postage, i can send you some used ones ?
Mark Mawson
Aug 31, 2015 07:09 PM
markk
18
Aug 17, 2015 05:19 AM
Aug 14, 2015 07:29 AM
Gadget
Aug 13, 2015 08:19 PM
Old ford
Jul 31, 2015 06:50 AM
