Bleeding Cosworth ABS system
Old May 31, 2010 | 05:20 PM
BRAMMER's Avatar
BRAMMER
Default Bleeding Cosworth ABS system
The system needs to be bled on mine and need to know the correct sequence.
I'll be using an eezibleed so have that side of things sorted but what i need to know is what corner do you start and finish with??
I thought it was this but i may be wrong:
LR, RR, LF, RF
Also what the deal is with the ABS pump - plugged or unplugged - do you need to let the pump prime for the rears only.
As much correct info as poss please
Old May 31, 2010 | 05:32 PM
cossiejay's Avatar
cossiejay
start with the wheel that is the fervist from the servo and work that way sorry about the spelling
Old May 31, 2010 | 05:34 PM
RS SHAUN's Avatar
RS SHAUN
i think you bleed with ignition on aswell chris
Old May 31, 2010 | 05:49 PM
bad boy rs's Avatar
bad boy rs
yes first position
Old May 31, 2010 | 06:51 PM
There's a few different ways of doing it, I do mine by disconnecting the abs pump MOTOR by pulling the connector then start nearest the pump working next nearest etc, with ignition in "accessory" position 1, this ensures the abs valve block has opened.
Old Jun 1, 2010 | 05:44 AM
BRAMMER's Avatar
BRAMMER
When you talk about the pump motor are you talking about whats on the drivers side with res bottle on or the block on the passenger side? and which connector
And can you show the formation i should go
Old Jun 1, 2010 | 06:50 AM
Mark Barber's Avatar
Mark Barber
bleed rears by putting the ign on as said and just open the bleed nipple and just touch the foot brake slightly fluid will come out of the nipple once air stopps bubbling out tighten up the nipple
do the same on the other rear one
then turn off the ign
and bleed the fronts conventionally
ie open nipple push brake down fully then tighten nipple release pedal and repeat this till air stops
then finish with the one closest to the master cylinder and repeat process as on the other front one
any probs give me a call
Old Jun 2, 2010 | 07:08 PM
BRAMMER's Avatar
BRAMMER
Right tried it today, one question is should the pedal feel like it springs back or does that mean their is more air in the system??
Old Jun 2, 2010 | 07:16 PM
Shouldn't feel springy at all, I mean the actual pump motor on the drivers side, underneath the reservoir bottle area facing front.
Old Jun 3, 2010 | 03:31 PM
Papillon's Avatar
Papillon
i bought a cap with the same theradsize, drilled a hole, took the aircompressor gun in the hole, had a mate push air in the system while i worked the nipples (not his), done in 5min
Old Jun 3, 2010 | 04:18 PM
BRAMMER's Avatar
BRAMMER
Re-bled the system and all sorted
Ignition on Pass rear - Driver rear
Ignition off passenger front - driver front
Old Jan 4, 2014 | 02:57 PM
Cossy Mike's Avatar
Cossy Mike
old post Chris but did you have any problems with air in the ABS block afterwards??
Old Jan 4, 2014 | 03:16 PM
cossie moon's Avatar
cossie moon
Durham RSOC member
Loosen the centre pipe on abs block if you have air trapped in it.
original
Apr 28, 2026 05:20 PM
jay030787
Aug 17, 2015 06:16 PM
rdvil
Aug 15, 2015 12:11 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
