oil drain hose
fitted a new turbo at the weekend took it for a drive and 15mins later the oil drain hose split in to i must have tightened up the jubilee clip to tight. have read not to use jubilee clips but i never knew as thats what was on it originally. has any one a spare dont want to spend 45 for a bit of hose. or can i use somtehing else? its just one thing after another with this car
FYI:
the clips that were on that pipe originally are the same that are on the breather hoses on the rocker cover, i.e green "pinch" clips. they expand slightly i think, well enough to stop the hose splitting anyway.
