Cossie management parts
Got everything here bar a loom and crank trigger. Came off a perfect working car, been stored for a while but all VGC.
Polished efi inlet
EFI to MFI adaptor plate
Air temperature sensor
Coolant temperature sensor
Camshaft trigger set includes disc, brackets and sensor
Polished cossie throttle body with modified linkage
Ally throttle cable bracket
Throttle cable
Throttle position sensor
Idle speed control valve
Fuel rail
Fuel pressure regulator
803 dark green injectors
Ignition amplifier and heatsink
3 bar map sensor
Fuel filter and lines
Level 8 ecu with chip for 1600 cvh/ greens/ 3 bar etc
post or collection welcome from PE7 2BE. Call or text on 07946367994 as i'll forget to check back on here LOL
Polished efi inlet
Throttle cable
Fuel rail
3 bar map sensor
yeah i often see and speak to jano and he said he cant even get hold of the guy that makes them. Its the pretty much last bit i need and is the bit you have to put on before you put all the top pulley etc back on.
I'll bare that in mind mate as i know me and many others will need one. Im sure im not the only one out there who is collecting everything to do cossie management at moment.
