General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Everthing happen after I change the fuel filter..
then I start the car and the car didnt start after a while I decide to use a spray to help to start.well did the job very well.
II went to work about 10 miles I parked the car,after 8 hours I finished work and the car the started I have to use the magic spray.
Had a similar problem with a later focus diesel I serviced, something to do with fuel pressure solved it by bump starting the car a few times at it was sorted
p.s you did prime it first right?
Reason: Kosman bumed it
I did not prime I donnt know how to.
I went back to the car token the return pipe from the filter and I hear something like fff fff.
I pressume will be air in.
Now how to I take the air out?
