under pressure
just found out me fuel pressure reg is leaking.
so got me a nice aermotive jobby with a gauge
so wondering what me fuel pres should be set at at idle
car has 803s
not sure what chip new one on way from stu
t3
-31
any ideas people????cheers
car has 803s
t3
-31
cheers have it set at 3.5 now
so should it read at 0 when the engine off?
as that what it showing!!!
seems to dip down when i rev the engine is this right?
might have to rewire me pump
yes it will drop to 0 with out the engine running as the pump will not be running constantly. when u plug the pipe back on it should drop to 3bar and the fuel pressure should raise on a 1:1 ratio with the boost so if ur pushing 2bar of boost the fuel pressure should raise to 5bar
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
