a
Old May 27, 2010 | 08:08 PM
chris1987pownall's Avatar
chris1987pownall
Default a
hi all need abit of help[LIST]
1. does a 1.6 ford fiesta zetec s eco work with a 1.7 puma engine an do yo need the key. 2. does a fiesta zectec s 1.6 gearbox fit the 1.7 puma engine. 3. does the fiesta zetec s wiring fit the 1.7 puma engine. 4.do you need the 1.7 fuel pipes an can 1.6 fiesta zetec s pipes be used thank all
Old May 27, 2010 | 08:58 PM
James998's Avatar
James998
You need the ecu, key, engine bay wiring loom, o/s engine mount and underbonnet fuel pipes to fit a 1.7 into a zetec s mate.
Hope this helps.
Oh, and the interior loom/clocks if the engine came out of an older puma with a non-digital dash.
Old May 27, 2010 | 09:22 PM
chris1987pownall
will the ecu out of my fiesta not work m8 coz i bort this engine of some an he said he would send me everything i would to do a convertion an i dont think he has sent every thin
Old May 27, 2010 | 09:25 PM
James998's Avatar
James998
Needs to be a 1.7 ecu matey, if you need any other help quickly get over to www.zsoc.com as there is alot of people who have done the conversion on there.
Old May 27, 2010 | 09:27 PM
chris1987pownall
nice one m8 thanks
Old May 27, 2010 | 09:30 PM
m4tt274's Avatar
m4tt274
type properly, i sense another 'fatford' or whatever that nob was called.
but mate honestly, if your not sure of these basic things are you sure that you wanna undergo this engine swap?
Old May 27, 2010 | 11:12 PM
chris1987pownall
sorry to bother again do you no if can buy the parts e.g if i was to buy them off another puma come i put then on mine ( eco,key.wiring loom. ect i have tryed to speak to them on that site no one is wrighting bk cheers m8
Old May 27, 2010 | 11:20 PM
chris1987pownall
i have got an 1.7 puma engine off ebay an they said they would send all i needed for the convertion mate but think i have been riped off just wanted to no if i could use the bit out of my zetec like the ecu bits like that
