maximum compression for n/a engine?
Old May 27, 2010 | 01:29 PM
Escy's Avatar
Escy
Default maximum compression for n/a engine?
I use Tesco 99ron, wondering what's generally accepted as the highest compression to safely run on an n/a engine. Thinking of upping mine.
Old May 27, 2010 | 01:35 PM
lead_foot's Avatar
lead_foot
is awesome
Depends on alot of things like the design of the combustion chamber, design of the tops of the pistons, ect
Old May 27, 2010 | 02:00 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it does depend on alot, but 11:1 shouldn't be too bad, 12:1 would need a lot of timing taking out of the map though.
Old May 27, 2010 | 02:16 PM
OldDan's Avatar
OldDan
I ran 12.5:1 on Tesco 99. The option was there to run 13.5:1 but would need to swap to carless.
Old May 27, 2010 | 02:22 PM
Escy's Avatar
Escy
Engine is a Toyota 4age 20v. It's 11:1 as standard. I've got some updated cams to go in and was thinking of raising the compression to about 11.5:1, maybe more.
Old May 27, 2010 | 02:24 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
12:1 isn't to high but as said would need mapping to suit
I have one built for 13:1 but dont think it's gona like pump fuel.
Old May 27, 2010 | 03:02 PM
timrud's Avatar
timrud
I know of XE's running 13:1
Old May 27, 2010 | 03:51 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Very dependant on the cams you are using, 13:1 or even 14:1 or more on lairy cams isnt a problem as your dynamic compression ratio will be so low anyway.
Ask your cam manufacturer what they recomend, its pointless asking anyone else!
Gadget
Aug 26, 2015 01:02 AM
155lee
Aug 14, 2015 11:21 AM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
