Genuine rs500 inlet complete,super 8 l8 ecu and sub loom
I have a genuine RS500 complete inlet for sale,(comes with throttle housing,ISCV and 4wd pf09 tps, 8 dark green 803's and genuine fuel pressure regulator with aeroquip hosing and fittings plus the throttle bracket)
The inlet is mint,been bead blasted and the 8 greens were sent off to IMA Racing(phil-the boschman) off here for flow testing,cleaning,new filters and o ring seals.
The l8 ecu with super 8 board has the 12 point adjustable boost control facility built into the ecu along with air injector use for boost control.I also have the sub loom to convert to an 8 injector set up.***NOW SOLD****
Heres a few pics
Thanks.Lee.
Heres a few pics
Thanks.Lee.
RIB1122
Aug 12, 2015 08:51 PM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
