broken clutch arm
Old May 25, 2010 | 05:56 PM
MERKUR XR4ti's Avatar
MERKUR XR4ti
MERKUR XR4ti
Default broken clutch arm
I have a broken clutch arm on my T5 where can I get one guys Please I only noticed when I fitted a new clutch HELP
Old May 26, 2010 | 05:56 PM
righthooker's Avatar
righthooker
i spent over 6months watching ebay and had no luck, but there is an American trader on ebay motors who has them new , i just bought one and i think it was about $30 posted
Old May 26, 2010 | 07:41 PM
cossiewill.'s Avatar
cossiewill.
Brit With A Tan
How bad is the arm you have broken? could it be welded or used and a template for someone to fab you one up?
Also i am not 100% sure, but the mustang and a few other cars stateside use the T5 box as well. the part i am unsure about is the bell housing differnces, but the boxes are defo t5's. so it might be worth looking to see if one from another model will work.
a quick look on ebay showed up this:
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
Old May 26, 2010 | 08:45 PM
MERKUR XR4ti
MERKUR XR4ti
The mustang uses a different clutch and arm and the Thunderbird is hydraulic. There is so many car out there that use the T5 borg warner box but nothing as yet that will fit. But I am on the case and I dont get beat My clutch arm is toast The old owner must have had a big clutch or fly wheel issue at some point and the clutch fork took the brunt of the mess in there . Thanks guys I will post the information when I have it and I will have it as I know what FORD are like It is off another FORD I bet my LIFE on it.
Old May 26, 2010 | 09:43 PM
righthooker
is the merkur box not the same
Old May 27, 2010 | 09:35 AM
Phone up TVR/breakers ? they use the same arm I'm sure on some of thiers, also try a type 9 part, just a guess might fit, there are over 264 versions of T5, used by ford/chevy plus loads of others, although a borg warner design the T stand for Tremec now who have the rights to make this box.
Old May 27, 2010 | 09:48 AM
Just been on ebay looking under clutch arm and ther eis a Ł4.95 buy it now for a type9 box, though I don't have both to compare you'll have to see what you think there's I think presently 4 on there, as well as brand new 4wd(tractor) cossie arm for Ł20!!
Old May 28, 2010 | 07:46 AM
MERKUR XR4ti
MERKUR XR4ti
Thank you Tabetha I my self have been looking too, The type 9 ones off the 1.6 1.8 2.0 dont fit, as I have them the next to try is the 2.3 & 2.8, 2.9 one's, I have a spare one in my garage off my old capri . This weekend we will see hey
Old May 28, 2010 | 05:18 PM
Good luck!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
mjonathan24
Oct 29, 2015 10:39 PM
