Fiesta turbo complete EFI engine.
I'm looking at selling my current FRST engine, heres a quick spec-
Bottom end - Rebuilt approx 5k ago by myself, new rings, bearings and ARP bolts fitted to the rods- i have pics of the rebuild and it was a low mileage(approx 60k) example before i started so all was good with the bores and crank, pickup was cleaned and new sump fitted also.
The head was rebuilt with new bronze valve guides and a skim to insure it was perfectly flat before being fitting along with a vernier pulley and standard cam fitted(is a bit tappety already but it pulls very well still)
It is currently fitted in my erst which is running OFAB management so it can be seen/heard running if need be.
At the time of the rebuild a new oil, water pump and cambelt was also fitted.
It also produced a very healthy 171bhp @12.5 psi on a standard turbo.
£350
i also have a spare standard efi head i was thinking of getting rebuilt- in very good condition if the buyer wants any spares to go with the engine.
edit- i will post pics if wanted but its just like any other efi cvh turbo with a black rocker cover.
£350
If i stripped the bay out and included
tall engine including efi flywheel
turbo, -31 and manifold
inlet and beige injectors
ofab ecu with 195 powerchip
map sensor,edis, cps etc
I'm not willing to take out the loom so thats staying.
I'd want a good £800.
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
