Just opened the cossie to find this.....
Old Jan 16, 2005 | 12:09 PM
avengerpenguin's Avatar
avengerpenguin
Default Just opened the cossie to find this.....
While its been off the road for a couple of weeks, someone has got in and fitted a sink!!!!!!!!
Old Jan 16, 2005 | 12:12 PM
Alps Pacino's Avatar
Alps Pacino
mine looked like that when me mate spilt a full large coke from burgerking. I was sat in the carpark sucking it out with a straw
ECU Monitor Enthusiast
Sunroof drain tubes are blocked - Fix it or the sunroof will rust shut !
Even when you have cleaned up the water, When you drive the car and go round corners,
water will drip out of the inner roof drain gulley.
Old Jan 16, 2005 | 12:15 PM
Disabled Account's Avatar
Disabled Account
Sunroof leaking..........quite common
My white Saph did the same...........worth checking
the water drain tubes ane not blocked with dirt.....
avengerpenguin
Another job to add to the never ending list
Old Jan 16, 2005 | 12:16 PM
Disabled Account
OYE you lot!!!!
Weston Super Mare - Pizza Hut meet tonight?????????
7.30 ish????????????
Old Jan 16, 2005 | 12:17 PM
avengerpenguin, Is that a USED condom in the passenger foot well ?
My cars in bits at the body shop nearly done tho
Old Jan 16, 2005 | 12:19 PM
Doug Stirling, Yes I will come out to play
Old Jan 16, 2005 | 12:20 PM
Disabled Account
OK...will put a post up now
Old Jan 16, 2005 | 12:46 PM
avengerpenguin
If it is its not mine and its not there now so they must have come back for it
Old Jan 16, 2005 | 12:48 PM
Filthy Rich's Avatar
Filthy Rich
Old Jan 16, 2005 | 12:50 PM
Disabled Account
Sean, your Cossie has a water feature now.........good selling point
See the other thread for the Pizza Hut meeting tonight..
Bring the Mrs and kids if you want
Hansenturbo's Avatar
Hansenturbo
Old Jan 16, 2005 | 01:39 PM
Smit's Avatar
Smit
The 60ft Launch King
concerning the drain tubes..how would u go about unblocking them? genuine question
Old Jan 16, 2005 | 01:41 PM
Azrael's Avatar
Azrael
In my case they didn't block, they just fallen off. You can take them out (requires stripping interior) and push something through them or whatever - even get new onses - rubber hoses schouldn't bee very expensive.
Old Jan 16, 2005 | 01:44 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
big long pipe cleaner/Mr Muscle drain unblocker or get it in a garage and use their air line smit
Old Jan 16, 2005 | 02:22 PM
svony's Avatar
svony
As above compressed air and inspect both ends....
Old Jan 17, 2005 | 10:12 AM
magic randy's Avatar
magic randy
150 psi
Old Jan 17, 2005 | 02:23 PM
Smit's Avatar
Smit
thanks
Old Jan 17, 2005 | 05:03 PM
rapidcossie's Avatar
rapidcossie
exact same happend to mine til i sorted the seals and unblocke the drains.
used to come in thru the interior light
DixieTheKid
Jul 23, 2023 10:16 AM
PaulinhoT
Oct 28, 2015 06:06 PM
James Porter
16
Aug 28, 2015 10:37 AM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
