cosworth idle trouble..HELP!!
Old May 23, 2010 | 11:07 AM
mark bugeja's Avatar
mark bugeja
Unhappy cosworth idle trouble..HELP!!
hi,iwas wondering if anyone can help me.i have a cosworth engine fitted to my mark 1 escort,everytime the engine is set to idle properly and turned of and started the day later it seems to loose its setting and does not idle properly.I have tried a different ecu, map sensor and injecters but the same happens,has anyone ever encountered this problem???
Any help would be gretly aprreciated,cheers.
Old May 23, 2010 | 02:42 PM
What do you then have to adjust to get it to idle correctly once again ?
Old May 23, 2010 | 04:32 PM
mark bugeja
clean the plugs (specially the fourth) adjust fuel pressure and sometimes the co setting.
could it be a faulty fuel pressure regulator???
i also have been told to check the Air temp sensor
Any ideas will help!!
cheers
Old May 23, 2010 | 04:42 PM
martysmartie's Avatar
martysmartie
PM replied to with the below:
Not air sensor this will have no effect at all, CTS, this tells the ECU info on the coolant temperature and hence can fuel accordinly these are basically thermisters as is the ACT and they go out of range after a while provides false info. The CO needs to be set to what the author has written that chip for. If you do not know it is normally written on the chip itself, same applies for FP. It is very rare to need to adjust this though as most chips use standard fuel pressure (3.5 BAR).
Martin
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
15
Oct 7, 2015 03:43 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
