Escort Mk3 or 4 Cosworth inner wings.
Old May 20, 2010 | 02:08 PM
Ferd's Avatar
Ferd
Default Escort Mk3 or 4 Cosworth inner wings.
Hi
Basically is it possible to use the original inner wings in the Escort MK3/4 for a Cosworth 4X4 project?
Seen a few conversions on the net and it seems 2wd can use them with some work and 4X4 use the Sierra front end.
Also what would be a good 4X4 base to use like the Xr4x4 say?
Ferd
Old May 20, 2010 | 05:27 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
in short yes and no mate ,
if your planning to fit the cosworth front end i.e cossie inner wings and bulkhead then the rst wings will need a fillet putting in as the arc of the rst wing is steeper then the cossie one ,
if your going rwd and want to keep the rst front end , just weld in cradel mounts and a tunnel ,
check my resto on here, will give you an idea whats involved in the front end ,
beef
Old May 20, 2010 | 08:25 PM
Ferd's Avatar
Ferd
Hi Beefy
I have seen your Cosworth conversion and read your topic more than once and it’s very nice.
Just looking into a 4x4 conversion without having to pull the front end off an Escort.
Ferd
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
