HELP!! Which Hoses For Cosworth 2wd Calipers?
Right, got some 2wd calipers which my mate is refurbin. Goin on my mk4 van so which hoses do i need? cossie 2wd ones or can i get away with rs turbo ones?? hoping to get them ordered when i know which ones so then can start to get on with my van
Cheers in advance
DaN
Cheers in advance
Well to start off you need banjo fittings to make the pipe side fed into the calliper as a normal straight flexi pipe will come in contact with the drive shaft, i made a set of these of for my fwd yb powered rst last year and cost about £25, that was braided flexi lines with banjo fittings one end and the normal fitting to screw into your exhisting solid brake pipe on the other, got all my parts from, www.raceparts.co.uk.
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
