Front brakes pipes issue?
I have Sierra RS Cosworth and I wanted to mont a Line lock system for the front brakes. As Sierra has 2 pipes each for one front wheel, I need 2 line locks.
BUT, has anyone connected the 2 pipes coming from the headpump into one pipe ("Y" connector) adding the Line lock and from there connecting the pipe to each wheel (another "Y" connector), by this I only use one Line lock.
Can anyone see problems in this?
- I hope you understand my explanation...
