Best breather system for 380bhp-400bhp
Old May 18, 2010 | 11:21 AM
COSSIE STE's Avatar
COSSIE STE
Default Best breather system for 380bhp-400bhp
As in title best breather system to go for preferably without having to drill an tap the rocker cover.
Cheers.
Old May 18, 2010 | 01:02 PM
BRAMMER's Avatar
BRAMMER
I run a bailey system on mine but i'm not sure how effective on my 400+ it is
Old May 18, 2010 | 01:05 PM
STUCOS's Avatar
STUCOS
Just purchased a spec r one ,same as rod tarry uses,so should be fine,have used bailey ones before with no issues.think they all need rocker cover drilled
cheeRS stu
Old May 18, 2010 | 01:11 PM
Staffi's Avatar
Staffi
Bailey will be fine for 380-400....
Old May 18, 2010 | 01:43 PM
RSRoy's Avatar
RSRoy
Are breather systems tested by Fast Ford once? I know they did a RS500 intercooler test once or twice before.
Old May 18, 2010 | 01:44 PM
Nash's Avatar
Nash
Cake lover!
Pro alloy which is a bailey style one on mine. I breath from the exhaust side of the block, inlet side of the block, and a return to the sump under oil level, then you have the atmosphere take off. Mine been fine so far.
A WRC style breath is allways going to be the best option but it does cost.
Old May 19, 2010 | 08:11 AM
COSSIE STE's Avatar
COSSIE STE
Ok thats great thanks everyone for the advice.
Old May 19, 2010 | 09:49 AM
grcossie's Avatar
grcossie
GGR ones, whit breathing from both side of block, and use the oe return under oil level
Old May 19, 2010 | 01:56 PM
DaveCrack's Avatar
DaveCrack
SpecR GRP A is spot on with mine!
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
ST-170
Sep 4, 2015 11:02 AM
