immobilser pats,
Old May 17, 2010 | 09:26 PM
airzfocus's Avatar
airzfocus
Default immobilser pats,
my car is dead at the min, car will turn over but wont fire up, had auto electrician out and he sed its the pats key transponder thing??? this has happened since using a bluefin handset to use as a diognostics tool, its immobilsed the car, just wondering what to do now as he said it could possibly of wiped my whole ecu, is there any way of sorting the immobilser side of things cheers
Old May 17, 2010 | 10:57 PM
evans2822's Avatar
evans2822
Sure Ive read somwhere you can reset Ecu by disconnecting negative lead on battery for 10 mins press the brake pedal here and there to dissapate any residual current then re connect? Never tried It so may be bollox mind lol
Old May 20, 2010 | 09:03 PM
RichieST's Avatar
RichieST
If it is immobiliser then it won't even turn over!
Old May 23, 2010 | 12:48 PM
fiestamk2's Avatar
fiestamk2
get another ecu and key.go bury salvage
gingerturbo
Aug 11, 2015 09:44 PM
Damo V
Fiesta RS1800/RS Turbo
Mar 7, 2006 11:34 PM
morto
Aug 17, 2004 08:54 PM
Stoned
20
Mar 31, 2004 04:55 PM
Stoned
18
Nov 30, 2003 05:03 AM
