breaking issues???
Old May 16, 2010 | 11:35 AM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
Default breaking issues???
ok recently got a new(to me) rs and its had the abs disconnected now this dosent bother me because the last one had been disconected the pumps belts ect have all been removed and the master cylinder has the pot on top the pot has the 2 outlets looped around to each other
the problem is tho the brakes are utter crap so i have a bit of money to spend and was thinking of upgrading all the front brake set up including changing the mastercylinder if its required so what should i buy is my question lol
so in simple terms what calipers / disks / pads / mastercylinder / servo do i need to purchase to make the brakes acctually feel like brakes
Old May 16, 2010 | 11:37 AM
jonny s2's Avatar
jonny s2
cossie 2wd calipers, or 4x4 calipers, cheap effective upgrade
Old May 16, 2010 | 11:42 AM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
do i need to change the master or servo for that tho???
Old May 16, 2010 | 11:50 AM
Karlos G's Avatar
Karlos G
Balls Deep!
No you dont mate stock MC and servo will be fine.
As an alternative if you are running 16" wheels or bigger then go for Focus ST 300mm discs with Mondeo MK3 Calipers and pads
If you look here https://passionford.com/forum/ford-e...els-today.html you can see them fitted to my car.
Old May 16, 2010 | 02:42 PM
jonny s2's Avatar
jonny s2
no mate, as above
Old May 16, 2010 | 10:15 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
By tasos77 at 2010-05-13
as karlos says mondeo calipers and focus I st disks. Is the cheapest i think! My rims are 16'', you can't use 15'' rims..
chowfornow
14
Jan 5, 2019 09:01 PM
SMILER258
Sep 28, 2015 09:04 AM
