i have a st 200 with lack of power! irmc is working fine have cleaned out inlet flaps and are free moving .no codes in ecu . has anyone got any idea`s cheers for any advise.
If the IMRC is owrking corecctly then it could be a blocked cat. Whereabouts in Hants are you and can get the car to Kent at all over the weekend and I wil take a look at it for you?
Jeff
imrc is good tryed two . all cats removed. plugs and leads bin changed got a wedding to go to cheers
Have ALL of the cats been removed though or just the main one as there are three of them on the 200's??
And even though you have tried two IMRC's are they actually opening the secondaries. Have known people try three or four IMRC's and all of them have been goosed.
yes all cats removed! yes secondaries are opening u can see this and feel it on the revs. flaps were clean last weekend and operated well.
