sanity check
Old May 14, 2010 | 06:55 PM
pauloopnorth's Avatar
pauloopnorth
Default sanity check
now removed
Old May 14, 2010 | 07:03 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:05 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:08 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:10 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:11 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:15 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:17 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:23 PM
j6kyt's Avatar
j6kyt
im sure its not beyond repair, surely its not that bad, whats wrong with it?
Old May 14, 2010 | 07:28 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:37 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:40 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:43 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:49 PM
pauloopnorth
now removed
Old May 14, 2010 | 07:53 PM
Mike Kerbey's Avatar
Mike Kerbey
cosworths are money pits to be honest mate, but for when they do work properly you'll then realise it was all worth it!
What was said to be beyond repair?
Old May 14, 2010 | 08:05 PM
pauloopnorth
now removed
Old May 14, 2010 | 08:10 PM
pauloopnorth
now removed
Old May 14, 2010 | 08:12 PM
pauloopnorth
now removed
Old May 14, 2010 | 08:22 PM
Mike Kerbey
No worries. Put up a list of the problems the car has and you will get plenty of useful answers and tips!
Old May 14, 2010 | 08:35 PM
pauloopnorth
now removed
Old May 14, 2010 | 08:45 PM
pauloopnorth
now removed
Old May 14, 2010 | 08:47 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Stick with it mate, it'll be worth it in the end!
Whereabouts in the country are you?
Old May 14, 2010 | 08:49 PM
pauloopnorth
now removed
Old May 14, 2010 | 08:53 PM
pauloopnorth
now removed
Old May 14, 2010 | 08:58 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I take it from your username that your from up north in the country somewhere!!
If you were a bit closer, I would have offered to lend a hand with the mechanicals and electrics side although I can't weld for shit!! Lol!
I know how you feel mate! I'm kind of in the same boat with mine at the mo!!!
Old May 14, 2010 | 09:03 PM
pauloopnorth
now removed
Old May 14, 2010 | 09:07 PM
pauloopnorth
now removed
Old May 14, 2010 | 09:43 PM
pauloopnorth
now removed,
Old May 14, 2010 | 10:01 PM
pauloopnorth
now removed
Old May 14, 2010 | 10:05 PM
pauloopnorth
now removed
Old May 14, 2010 | 10:09 PM
LHD220Turbo's Avatar
LHD220Turbo
i mean this in the nicest possible way; but if you just took it to someone who knew what they were doing in the first place, you'd be probably driving the car now
IF the shell is beyond repair, just reshell it and have some fun
Old May 14, 2010 | 10:21 PM
pauloopnorth
now removed
Old May 14, 2010 | 10:28 PM
pauloopnorth
now removed
Old May 14, 2010 | 10:29 PM
pauloopnorth
now removed
BJAS's Avatar
BJAS
You need to decide whether you actually like and want the car. If you do, then identify the problems and list them in the order in which they must be addressed. Start at the top and and work to the bottom. Don't set unrealistic timelines and make sure that you get good advice and and help to finally resolve each of the issues. Its just planning; nothing more, nothing less. The process can be a burden or a joy; its what you make it.
Restoring a car is has incredible ups and downs, especially if you do it properly. There will be times when you cannot even look at the car, and other times where you cannot wait to get on. But when it all starts to come together you won't regret it.
Here is a picture of my MKII RS2000 coming out of the paint shop. The restoration has to this point taken nearly 3 years and at times I have felt like quitting and dumping the thing. But now its going back together and the light is visible at the end of the tunnel. This is the really fun part.
So ask yourself; do you really like and want the Cossie or not?
Old May 14, 2010 | 10:42 PM
pauloopnorth
now removed
pauloopnorth
now removed
Old May 14, 2010 | 10:52 PM
BJAS's Avatar
BJAS
There is no point dwelling on what has happened; you cannot change it, and it certainly won't make you feel better. Learn from the past and don't make the same mistakes again.
You should regularly visit the guys who are now working on the car; ask them about what they are doing and get them to show you and explain. That way you will understand what is happening, what is going right and what is not. Get involved and keep an eye on it.
If you are unsure about an issue there is mountains of experience and advice available here. Just ask.
Old May 14, 2010 | 11:07 PM
pauloopnorth
now removed
Old May 14, 2010 | 11:09 PM
pauloopnorth
now removed
