Rs Turbo filler cap
i cut mine out from the back and replaced it with bits i cut out of my combi
havent got a pic from the underside but it was part of the combi origonal inner arch about 2" bigger than the cup
tacket the cup in and seam welded the plate back over
I've had a good look around the breakyard and this was the best of all..
Not good as you can see, the paint is blistering because of the rust behind it.
So i have made it myself, with some nice hard wood and a 'woodmill'?
cut the back out end put my pl8 in
Only need to weld it fully end finish it now
Matt Baxter
Sep 16, 2015 08:30 PM
