What to do about engine!?
Old May 12, 2010 | 05:28 PM
mattseries2's Avatar
mattseries2
Default What to do about engine!?
Alrite Guys!
Having a bit of trouble deciding what engine to put in my RST!
Ive just recently rebuilt my 1600 cvh with oversize pistons new bearing, pumps etc. Shall i convert to EFI with a stand alone managment or shall i go down the Zetec Turbo route?
I want more power!
Its running around the 200bhp as it is on the mfi setup.
Not sure weather to stay with the cvh or go full Zetec!! Or whats the ZVH route like??
Any opinions will be great
Matt
Old May 12, 2010 | 05:34 PM
bezo's Avatar
bezo
powered by K26
everyone will tell you not to go zvh thats for sure. not me though
all depends on your budget, ditching the mfi and going stand alone is the best option to start with.
Old May 12, 2010 | 05:39 PM
mattseries2
Yeh loads of people say not to bother with ZVH but im not sure why? Seams a pritty good conversion?
Matt
Old May 12, 2010 | 05:42 PM
puffit's Avatar
puffit
id stick with the 1600 and go gotech
Old May 12, 2010 | 05:43 PM
mattseries2
Yeh thats what i was gona go with, spoke to Jamsport and they do the complete kit for the S2 with ecu etc...
Old May 12, 2010 | 05:45 PM
bezo's Avatar
bezo
powered by K26
Matt
i run a zvh. seems to work to good effect.
there will be a few people who will post up why you shouldnt bother with zvh.
Old May 12, 2010 | 05:47 PM
mattseries2
What managment do you have on it mate?
Old May 12, 2010 | 05:50 PM
bezo's Avatar
bezo
powered by K26
gotech miniX, kept my dizzy, didnt bother with a coil pack as ive got a stainless steel flywheel and didnt want to change it.
Old May 12, 2010 | 05:54 PM
mattseries2
I see nice.
Whats the reliabilty like of the car?
What sort or power you running?
Old May 12, 2010 | 06:00 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
cosworth management
Old May 12, 2010 | 06:03 PM
mattseries2
Originally Posted by benjaminsarmy
cosworth management
Your tempting me mate!
Old May 12, 2010 | 06:06 PM
benjaminsarmy
lol
simple to do
Old May 12, 2010 | 06:20 PM
12_Second_rst's Avatar
12_Second_rst
I can't see why anybody would wAste money on cossie managment when it's more exspensive than the likes of Omex, haltech ,ms and gotech seems pointless on a 20 yr old system and still no coil pack etc without spending more cash standalone ftw
Old May 12, 2010 | 07:56 PM
benjaminsarmy
how much are the others ive got the whole cozzy management cheap 400 very cheap
can see yr point but is there any speed or performance difference
Old May 12, 2010 | 08:04 PM
jonny s2's Avatar
jonny s2
stick with the 1600 you just built, and run efi of your choice job done, less hastle alot cheaper, as you only need to fit ecu and loom. as you already have a fresh engine
Old May 12, 2010 | 08:25 PM
Rob_DOHC's Avatar
Rob_DOHC
Id stick with the 1600 you have just rebuilt mate and go efi as above..... if you look at it in black and white you WILL need efi at some point no matter what you do, doing an efi conversion now will make your life easier later.
Nothing too wrong with the zvh mate, but in all honesty it was a bodge done back in the day when aftermarket management and manifolds were expensive, you can probably make a low power zetec turbo for the same money as a zvh.
Good luck what ever you do,
Rob,
Old May 12, 2010 | 08:31 PM
jammerrs's Avatar
jammerrs
1600 FTW
look nicer in the bay imo
unless you spend big bucks on a zvh they dont like reving past 5500, or so i read
Old May 13, 2010 | 09:17 AM
bezo's Avatar
bezo
powered by K26
funny that mine rev limit is set to 7250 and is more than happy.
Old May 13, 2010 | 09:24 AM
bezo's Avatar
bezo
powered by K26
I see nice.
reliabilty is spot on, so long as you look after it. like any other engine
power wise 270atw, which was more than enough. im building my new engine at the mo, same spec as the last on, black top bottom end, one of our spec heads, newman cam and a rather interesting turbo. make for a good drive in a combi that weighs in at 905kgs
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
