vibrating braking
hi my brakes were vibrating and now its got worse, ive fitted new discs pads and calipers bled the whole system and put new fluid in and its still doing it, and now the pedal is making a sound as though im leting air out of a tyre, does anyone know what this could be?
many thanks nick
many thanks nick
On a similar note, my fiesta seems to grind when braking at slow speed sometimes. Doesn't do it all the time, and only at slow speed (like 10-15mph). I've checked disks/pads and they have plenty of life, also checked everything to make sure it's tight, and it is. Any ideas?
i cant find any leaks atall, i dont know if internal leaks are possible i dont know much about brakes tbh, it passed its mot today and they didnt say anything about the brakes, the bushes are worn quite a bit, but its just passed its mot, surely they wud pick up on that? ill check to see if theres any play
ok just jacked it up everything is solid no play on any of it atall, i forgot to mention it has 20mm spacers on it, could that be doing it? also could it be a wheel bearing atall?
