Timing setting
Old May 11, 2010 | 12:45 PM
neil73's Avatar
neil73
Default Timing setting
I recently fitted a new timing belt on my rs, set the marks up correctly and double checked it but it seams to stutter when coming on boost, I had the timing checked with a strobe light and set to factory spec, is the timing setting different for a modded engine? Mods are stainless system, k and n fillter, chip and 1 bar of boost.
Thanks in advance, Neil
Old May 11, 2010 | 01:44 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Im having the same kind of issue mate.The car will need a set up unless you know the line up for your dizzy.Other whys you be guessing even with strobe light.
Old May 11, 2010 | 05:23 PM
neil73's Avatar
neil73
when the old belt was on the timing mark on the bottom pully wasnt on tdc, it was on the mark next to it on the left, the grey mark on the pic
when i fitted the new belt the mark was on tdc, first belt was non gen but the new one is gen ford
Old May 12, 2010 | 06:24 AM
ROB7656's Avatar
ROB7656
if every thing was at tdc i cant see the belt change causing a problem.get it to a tuner.imo
FlashRS
Aug 30, 2015 08:07 PM
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
Steve Escos
Aug 24, 2015 07:56 AM
Zoggon
Aug 10, 2015 10:39 AM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
